Hi everyone (after long time of inactivity, just for one more post)
I need small help from someone that lives in different timezone than mine (I'm from Europe, UTC+2).
If anyone can tell me if the time displayed here:
http://www.thrash.pl/helptime.html
is the same as your time.
If you're living outside Europe, you should see different time and that is what I want to achieve (to show my local time for everyone, no matter what timezone someone lives). But I can't test it myself.
I know how to do it in php (that's easy), but if I am not so good in js.
https://linustechtips.com/topic/1435702-small-test-required/
You use JavaScript. JavaScript runs in the people's browser. So the time will be their's.
If you want your server's time, use PHP for example.
The browser doesn't get your server's time. It gets this code:
<html><head><meta name="viewport" content="width=device-width, initial-scale=1, minimum-scale=1, maximum-scale=1">
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<style>
#dimmm{transition: all 3s linear;display:block;width:100%;background-color:#FFFFFF;opacity:0;text-align:center}
</style>
</head><body style='background-color:#FFFFFF' onLoad='javascript:showme();'>
<div id='dimmm'>
<br><center>
<div id="txt" style="border-style:none;display:inline-block;margin:10px;color:#000000;font-family:Courier New;font-size:20px;line-height:30px;font-weight:bold;width:300px;height:80px;text-align:center"></div>
&nbsp;
</div>
<script type='text/javascript'>
function showme(){
document.getElementById("dimmm").style.opacity = "1";
function startTime() {
offset=2;
    d = new Date();
    utc = d.getTime() + (d.getTimezoneOffset() * 60000);
    nd = new Date(utc + (3600000*offset));
aa1=nd.getHours();
aa2=nd.getMinutes();
if (aa2 < 10)  aa2 = '0'+aa2;
aa3=nd.getSeconds();
 if (aa3 < 10)  aa3 = '0'+aa3;
    document.getElementById('txt').innerHTML =
    "now it's " + aa1 + ":"+ aa2 + ":" +aa3 + " here";
    var t = setTimeout(startTime, 500);
function checkTime(i) {
    if (i < 10) {i = "0" + i};  // add zero in front of numbers < 10
    return i;
startTime();
</script>
</body></html>
So the new Date runs in the browser.
PHP doesn't send it's code. The code, the browser receives will not contain the PHP code. I will just contain the stuff you write by "echo".
If you want to use JavaScript really bad, you can use it to call a website, which shows the time and extract the time string from there.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1435702-small-test-required/#findComment-15427677
<style>
</style>
<div id='dimmm'>
<br><center>
&nbsp;
</div>
function showme(){
offset=2;
    d = new Date();
aa1=nd.getHours();
    return i;
startTime();
</script>
</body></html>
This code (it's not mine) supposed to be timezone independent, that is getTimezoneOffset for.
EDIT: Finally I found my friend online who lives in different timezone and he confirm that it working (shows my time instead of his).
https://linustechtips.com/topic/1435702-small-test-required/#findComment-15427694
