So, I've been trying to get the full 16gb ram to work (had this pc for 4 years), it only is running 8. I tried to fix it which I thought I did but it just went back to the 8. I reset my pc and re plug my ram to see if maybe one was messed up but I think they work. I tried to play a couple games and they keep crashing on me. I don't know why, before sometimes my pc would run into a problem and have to restart. Before I could play games, but I noticed my pc is only using 8 gb instead of the 16, now I cant even play games. So to sum it up, how do I get the full 16, why is my game crashing is it because of the settings in the game like fps or something(sometimes the game would crash or my pc would) before this didn't happen. I had another problem too where my pc 50/50 of the time would "run" into a problem and it would restart, after one time itt would work for the rest of the day. This only started happening maybe a couple of months ago. I changed my ssd and hdd a couple of weeks ago, if that is useful information. Is this problem a power supply problem? Is everything in my bois look right? I need help with my Ram issue, I have game and pc problems, and before( hasn't happened yet) my pc ran into a lot of problems(restarting).
https://linustechtips.com/topic/1435701-pc-issues/
what slots are the rams, they should be at a2 and b2, might also try a1,b1
or try a1,a2, or b1,b2 (disables dual channel, but should work)
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15427654
side note: you also have XMP disabled, which is bad for your memory speed
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15427655
I have it in a2 and b2 and with the xmp do I want it at 1 or 2. Are both my ram sticks there? And the values are right? Why is windows only running 8gb.
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15427663
5 hours ago, homeap5 said:
But that "unlink" mode works for different pairs, not different sticks. So place for test in B1+B2 (or A1+A2) slots.
I’m not to sure what happened, my bios now reads that I have 16000 of memory and in my system I now have my 16. I guess the computer just fixed it’s self I changed the xmp to 2. I couldn’t find the unlink.
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15427927
Now it won’t show display, and my pc keeps turning off and on. I was wonding is it because I have too much shit plugged into the pc and the area. My pc isn't getting enough power. I got my pc to turn on. So now the pc is running but I can’t play any games, they crash after a little while.
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15428020
On 6/7/2022 at 9:50 AM, westly said:
I change the power options to 100% to 95%, re set my drivers, did a couple of performance options and so far, so good. I played tarkov for like 10 minutes no crash and I did a benchmark with furmark, didn't crash. Temp is a lil high though, I haven't cleaned my pc in while. I was wondering could it be my antivirus? I have to turn it off to download anything or open stuff. Like the fur, it would start downloading and crash, but with antivirus off it works. some games are like that too, and some games I have to run as administrator, or they won't open, like rust, I can't play unless I open as administrator. I was thinking it might be a power supply I have a 2080, with intel7 with 650mw. I have no idea how to check if it's the power supply.
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15429635
14 minutes ago, westly said:
I used unreal engine benchmark and I'm able to run at the highest settings with 100 fps. I honestly have no idea whats wrong.
What slots are the ram in now?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15430319
3 minutes ago, westly said:
a2 b2
Are you trying to run an OC on the GPU?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15430334
On 6/7/2022 at 12:05 AM, westly said:
They are the same 8gb ram stick. But I did see the value where different. I’ll try that.
45 minutes ago, westly said:
no I have not messed with anything with oc, only thing ive done is i turned my outer pc fans up 10%.
You're using two different kits of RAM. What are your XMP settings right now? Try disabling that to see if it fixes your issues with games.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15430404
about 15 minutes my pc ran into a problem. Every time Thai happens I can’t get and display when I turn my pc on I have to wait like 10 minutes for the ox to run again. I though it was my graphic card but why am I able to run benchmarks with no problems. Is it my power supply?
https://linustechtips.com/topic/1435701-pc-issues/#findComment-15430436
