yes
https://linustechtips.com/topic/1435410-need-help/#findComment-15425389
52 minutes ago, Nukelolz said:
Is it normal for my CPU to go from 30 Celsius to 80 Celsius within two seconds of running Conebench R23then slowly climbs from there. And after I stop it it goes done to 45 ish in 1 second
 12gen  i7 12700kf cpu
NH-D15s coller
https://linustechtips.com/topic/1435410-need-help/#findComment-15425448
Sounds about like my 5900X... peaks at 87C though.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1435410-need-help/#findComment-15427393
