i got a 140mm fan slot on my case but i got a few things in the way. i chacked and a slim fan will fit there no issue but i cant for my life find a goddamn 140mm slim fan for sale
i there any company that makes those?
or do they just dont exist?
cpu: 5950x
mobo: asus tuf pro x570
gpu: 3090 FE
ram: 32gb G.SKILL Trident Z 3200 c14
psu: Antec HCP1300w Platinum (overkill i know...got it for a good price)
thats all needed right?...i didnt study for this exam....
https://linustechtips.com/topic/1434839-slim-140mm-fan/
They do exist.
Example :
http://www.cryorig.com/xt140_us.php
If the available options isn't good enough for you.
Alternatively, you can try searching for 140mm to 120mm fan adapter, and just use a slim 120mm
If you have 3d printer, or there's somewhere you can place a custom order for cheap around.
You can 3d print 140mm to 120mm adapter.
https://www.thingiverse.com/thing:753551
https://www.thingiverse.com/thing:4901338
Refresh before you reply
https://linustechtips.com/topic/1434839-slim-140mm-fan/#findComment-15421394
@orzeI'm blind the silverstone is not actually 140mm xD. There's an old Raijintek, another old Silverstone, an Old Thermalright, and an old Prolimatech (best performer). But they're all really hard to find.
The Jonsbo is not out yet, but should be in a few months on amazon/geizhals eu. Or atleast aliexpress, jd/taobao (via a forwarding service like superbuy).
https://linustechtips.com/topic/1434839-slim-140mm-fan/#findComment-15421601
Scythe appear to still make slim fans, and it looks like you actually buy them!
https://www.amazon.com/dp/B003E00ZIU
I've only had one Scythe fan, so a small sample size, but it still works after 11 years (knock on wood).
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/1434839-slim-140mm-fan/#findComment-15421635
thats a 120 xD
but all good ill keep searching. might have found a arctic 1 but tis super expensive
cpu: 5950x
gpu: 3090 FE
https://linustechtips.com/topic/1434839-slim-140mm-fan/#findComment-15422423
@orze
Here's all the ones sold in the past on the EU's version of PcPartPicker:
https://geizhals.eu/?cmp=1956029&cmp=1066546&cmp=890483&cmp=1054905&cmp=1244763&cmp=1062128&active=0
Prolimatech Ultra Sleek Vortex 14 is the highest performing slim 140mm ever designed. Though the new Jonsbo might be same or better, and then the Cryorig was really close 2nd place, And the Thermalright there about 2-2.5th place
https://www.jonsbo.com/en/products/HF1415Black.html
https://www.jonsbo.com/en/products/HF1415White.html
https://linustechtips.com/topic/1434839-slim-140mm-fan/#findComment-15422482
@orzeYou're in luck, Arctic Cooling just launched their slim 140mm fan. Definitely gonna have more EU/US availability than the Jonsbo, + the performance should be similar or better on the Arctic P14 slim:
P.S. It's already out in the EU and on US Amazon:
https://www.amazon.com/ARCTIC-P14-Slim-PWM-Pressure-optimised/dp/B09SLPRYYZ/
https://geizhals.eu/arctic-p14-slim-pwm-pst-acfan00268a-a2747530.html
https://linustechtips.com/topic/1434839-slim-140mm-fan/#findComment-15431481
