What’s a better monitor?
That IBuyPower computer comes with a AMD RX6500 which is a low budget video card that's best suited for 1080p gaming. It will struggle a bit at 1440p, especially as it has only 4 GB of RAM.
This being said, both of those monitors are 1440p but the second is up to 170Hz and the first is up to 240 Hz with HDR.
You can compare the monitors by reading the RTings reviews:
XG27AQ : https://www.rtings.com/monitor/reviews/asus/rog-strix-xg27aq
PG279QM (assume this is the model for first monitor) : https://www.rtings.com/monitor/reviews/asus/rog-swift-pg279qm
As you can see if you check those reviews, the XG scores a bit better at everything - it seems you get a better quality panel but you trade a bit of Hz and HDR, which honestly, I don't think it matters.
How often you'd use HDR... I don't know... but for sure you won't even get 120fps in most games with that RX 6500 (and the low end 12100F Intel cpu) so you really don't need 240 Hz refresh rate.
This being said, if you didn't order that system already, I'd encourage you to pick something better if your budget allows.
Instead of spending $500 on the monitor, spend $2-300 on a decent 24" 1080p monitor with 120-165Hz and bump up the system to a six core and a RX 6600 or nvidia equivalent and maybe 16 GB of memory.
For example Gigabyte G27Q at $250 : https://www.rtings.com/monitor/reviews/gigabyte/g27q
