So I got a 780 ti few days ago and noticed some weird things while gaming.
- as soon as I run any game, the GPU load hikes to 98% even at 1080p. Games I have tested are cry 3, bf 3 and bf 4. I play all these games at ultra, 4x aa.
- the temperatures I get while gaming with auto fan is 85% which is quite high too.
Is it normal to get those temperatures and GPU load while gaming at 1080p on the 780 ti?
My rig- nzxt 410 case with 8 fans, amd fx 8350 with noctua nh d14 heat sink.
My cpu load is at 50% while gaming in ultra, and the temperature is 35 c.
https://linustechtips.com/topic/143473-780-ti-gpu-load-and-temperature-problem/
Seems a bit high, what is the room temp?
As a comparison my reference blower fan 780ti runs at 72C under full gaming load and fan speed around 70%, room temps range from 20-25C.
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
The fan speed is kinda high. Which brand manufactured it, or is it a reference cooler? And load wise, it seems fine.
Case: Corsair Vengeance C70 Gunmetal Black CPU: i7-4770k Cooler: Corsair H100i RAM: 8gb Corsair Vengeance Pro GPU: ASUS Direct CUII 770 MOBO: Asus Maximus VI Hero PSU: EVGA Supernova 1000 G2
temps being reached , cooler and whats your room temp please then we can help :)
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
totally normal load ,totally normal temps for auto fan set ,how ever set a manual fan speed profile if you'd like to hit lower temps ,but 85° is still fine
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
I meant 83 degrees instead of %..
Its an evga superclocked 780 ti...if I manually set the fan to 70%, the temperature drops down to 77 degrees.
My room is pretty cool as I have my windows open 24/7
I was planning to over clock it, but it is already heating up quite a bit..:(
Any suggestions?
PS.. This form is freaking awesome.. second post, and I got so many replies in just an hour.
Thnx
Any suggestions?
Thnx
the single fan refernce superclocked? Cause that would explain it, and those would be norm. Especially with fan at 70% and temps at 77C.
