14 minutes ago, BILIDQBQI said:
Do we have some cheap memory that is ddr4 3000 32gb one bar? I'm actually confused.
Errr, the question is why do you want 1 stick ?
Refresh before you reply
https://linustechtips.com/topic/1433176-a-memory-problem/#findComment-15409931
Plus, you need to define "Cheap"
https://linustechtips.com/topic/1433176-a-memory-problem/#findComment-15409941
So let me get this straight, do you want a 2x32GB kit or a 2x16GB kit?
Where do you live, what sites do you use for purchases, and what system is this going in? A memory kit recommended for a 1st gen Ryzen system is going to be a lot different than a kit recommended for say a 5950X or a 12700K.
https://linustechtips.com/topic/1433176-a-memory-problem/#findComment-15409946
