Cooler for Ryzen 9 5950x
Lusss
Would the Mugen 5 ARGB do a good job at cooling down the Ryzen 9 5950x ?
I've been looking around for an air cooler and I like this design but I just wanna know how good it would perform if the CPU was at constant 90-100% usage.
It looks alright. It has 6 heat pipes, as far as I can tell from their website. Since I'm guess that you like RGB, an aio would work as well
Specs: 11700 | RTX 3060 | 32gb 3200mhz | 1tb 970 + 2TB HDD | Lian Li O11D Mini X Black
I'm 15 and live in the US
I run a 5900X / RTX3060ti build in a Corsair 4000X case with a Mugen 5 Black Edition, Corsair iCUE Commander and six 120s.
It runs 38C-42C idle, 57C-65C under moderate load, I almost never see over 72C unless I do a Cinebench R23 test.
Peak, CB R23 runs 87C with PBO, 76C without. Approximately 1-2 minutes idle to peak, or peak to idle.
One reason I run the iCUE Commander setup and recommend it, is its ability to address RGB fans on a temp-monitor basis.
Mine are setup to range blue to cyan from 28C-84C, cyan to red at 88C. Max fans at 80C, system shutdown at 89C.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
which variant are the six 120s? ml120s?
Three front mount ML120s included in the case, three LL120s topside and rear.
