Different Results on Power Supply Calculator Websites
Solved by Pandur,
5 minutes ago, milesuy said:I am researching whether my system can handle 2 GPUs and a Ryzen 9 5950X. I tried checking multiple PSU calculators but they have totally different results.
- Which calculator would you use or recommend?
- Which calculator listed below is the most accurate?
- How much wattage would you recommend for the specs listed below?
- I currently have a 1050W PSU from In Win (Model: P105), it is 80+ Gold rated. Is this good enough for the specs listed below, since it is within the wattages listed from the 3 out of the 4 calculators below?
- I'm planning to use the system for Folding@Home and for paravirtualization (2 gamers, 1 PC).
The specs I entered on the calculators are the following:
- 1 NVME SSD
- 2 SATA 3.5" HDD 7200RPM
- 2 SATA 2.5" SSD
- 2x RTX 3070
- 7x Fans
- No water cooling
- ATX Motherboard (ROG ROG Strix X570-F Gaming)
- 2x 16GB DDR4 RAM
- Ryzen 9 5950X
I would say your 1050W is good enough. You could use the average of the four results. (872W btw)
3 minutes ago, Mel0nMan said:Why 2 3070s, is my main question. Render farm? Else, thats useless
*cough*mining*cough*
No but seriously, two gamers one pc. Even if it sounds dirty, they can use one GPU each.
