Up grading monitor
cavmedic
Have a Asus tuf 1080p 165hz using hdmi display right now.  Will going to a 4k 60hz with displayport  be a big improvement.
Depends. 60hz is not ideal for advanced gaming, especially if you record gameplay. 165hz is much better suited to advanced gaming.
Ask me how I know. I just spent $2700ish on a 5900X / RTX3060ti build because I thought my previous 1700 CPU and GTX1650S GPU were the reason I was having issues recording gameplay. Turns out the 60hz display I have is more likely the reason, and while I don't regret the new build, I think I could have done better with a 3800X / 3900X / 5600X / 5700X / 5800X and an RTX3080ti for the same money, and I honestly think the 1700 and GTX1650S would have been fine for my purposes with a 144-165hz monitor.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
Imo, as soon as gaming is in the equasion, something around 144Hz becomes a minimum requirement. For that reason i'd suggest to go with a 1440p 144Hz monitor over a 4K 60Hz one if you really want to upgrade to something higher resolution. If you have us a budget we could give some firm recommendations.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
That is not a big improvement to me actually, it sound more than downgrade. 1st you need to make sure your GPU is powerful enough to handle 4K gaming, else you will getting a very low fps. 2nd from 144hz to 60hz is big downgrade for gaming.
If you go for 144hz 4K then that is another talk and this will be a big improvement as long your GPU can handle it.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
Actually I'll say, yes, you will see some improvement. By the fact that you are either going from 24 to 27/32 inches alone - or you're going from 1080p to 4k at the same 27 inch, that will also show some very significant upgrade.
In a certain kind of game, it could be worth it, not in competitive title for sure though.
Visually it will be an improvement, especially overall picture clarity and details. But I would at least want 120Hz. Depending on the budget I would go for 4k 144Hz or 1440p 144Hz rather than 4k 60Hz.
Desktop: i9-10850K [Noctua NH-D15 Chromax.Black] | Asus ROG Strix Z490-E | G.Skill Trident Z 2x16GB 3600Mhz 16-16-16-36 | Asus ROG Strix RTX 3080Ti OC | SeaSonic PRIME Ultra Gold 1000W | Samsung 970 Evo Plus 1TB | Samsung 860 Evo 2TB | CoolerMaster MasterCase H500 ARGB | Win 10
Display: Samsung Odyssey G7A (28" 4K 144Hz)
Laptop: Lenovo ThinkBook 16p Gen 4 | i7-13700H | 2x8GB 5200Mhz | RTX 4060 | Linux Mint 21.2 Cinnamon
4K will make fonts and everything that is generated as a vector in a page (lines, shapes) look very crisp.
More pixel density will also make content display in a more condensed way. So if you previously looked at a 1920px per 1080px image it filled the whole screen. Now it will only fill up 1/4th of your screen. So you will have to scale up fonts in your OS, otherwise text will look very small.
But, on the other hand, when you'll be watching images or videos of high resolution (4K and above), you will see incredible detail.
60Hz will be just the standard baseline frequency and with a 4K monitor it will be a slower gaming experience. Especially since your video card will work harder to render 4 times more pixels, but at lower refresh rate. It should be playable, though, just not as fast-as-lightning as before.
As someone who moved from a HD 24" monitor to a QHD 32" monitor and now to a 4K 32" monitor, I can say that for me resolution and refresh rate are not the most important thing. Gaming is not very important to me, though, I play only casually. Monitor size and colour accuracy are by far the biggest improvements. Bigger monitor gives you a lot more space for multitasking and good colour accuracy make that 4K content look amazing.
There are lots of cheap 4K panels with terrible colours, I returned one before I got my latest. 4K is just not that worth it when colour accuracy is crappy.
I'd focus on these, personally:
- size / diagonal
- colour reproduction, sRGB spectrum coverage ( at least 99%)
- brightness
- panel uniformity
- IPS with good viewing angles - this isn't just a gimmick, it's very important for image consistency, otherwise you'll only see the correct image from one single centre point
Refresh rates are not that important, though higher ones will make the image have better persistence and reduce motion artefacts. Which helps in gaming, ofc. But that's not much if the other specs are just bad.
You get what you pay for, very rarely you can find cheaper monitors that excel at something. Unfortunaly, for higher quality you have to fork out more. Decent 4K monitors start at between 450-500 bucks for larger ones. Smaller ones can be had for somewhat less but it's not worth getting a 4K monitor at below 32", imo. Even 32" looks a bit condensed at 4K, probably something close to 40" would be optimal to avoid having to rescale stuff.
What is the use case?
I'm currently using a 4K display at 60Hz (does 120Hz with compression, but usually too lazy to enable it - I mostly play RTSes). I have a 3440x1440 100Hz display next to it that I haven't plugged in in 9 months.
FPS gaming -> there's a benefit to higher refresh rates.
Most other use cases... ehh depends on size, color quality, etc.
Know your use case.
3900x | 32GB RAM | RTX 2080
1.5TB Optane P4800X | 2TB Micron 1100 SSD | 16TB NAS w/ 10Gbe
QN90A | Polk R200, ELAC OW4.2, PB12-NSD, SB1000, HD800
