I have a Gigabyte GA-990XA-UD3 for my motherboard, and ever since I got it my wifi card hasn't been able to pick up a wifi signal. I've tried ever troubleshoot I could find online and playing around with settings myself, and yet nothing has worked. This has been a problem for months now and I'm so tired of it. I've been able to get a wifi signal to my computer with an ethernet cable, but I can't get that cable hooked up to the router at my new house. I would like to figure this out.
I think this is my wifi card: https://www.amazon.com/dp/B0832MR4WB?pd_rd_i=B0832MR4WB&pd_rd_w=HpxF7&pf_rd_p=75edadd2-86be-4ee5-8051-494ee8e3e65e&pd_rd_wg=Ho5az&pf_rd_r=CE0RGBK6SP0EBB3BV1JP&pd_rd_r=4e7ff003-db7b-451f-b829-38af3a357630
Did the packaging for it come with any form of information about drivers? Like a link to go to in order to download any?
There's the possibility that the thing is dead, and if so you should return it and get a different wifi card.
It's not dead, I use it for Bluetooth and it works fine. And I tried downloading the driver for it through the website and the disk it came with, both didn't work.
I should also clarify the the Bluetooth divers download fine but the wifi drivers refuse to download.
Only thing I can think of is that it's defective, if one is working just fine but not the other. If you just bought this recently and are still within a return period I don't see any reason to not return it and try something from a different brand.
There's also those power line adapters that's a pretty good solution to be able to do Ethernet. Some years back I remember Jayztwocents doing a video about those, and I'd imagine you can find other videos on them.
I've tried a usb wifi adapter from another company and it didn't work either. Drivers wouldn't download it it wasn't working on it's own.
    I use it for Bluetooth and it works fine. And I tried downloading the driver for it through the website and the disk it came with, both didn't work. I've tried a usb wifi adapter from another company and it didn't work either. Drivers wouldn't download for that either. I should also clarify the Bluetooth drivers download fine but the wifi drivers refuse to download.
This is my wifi card: https://www.amazon.com/dp/B0832MR4WB?pd_rd_i=B0832MR4WB&pd_rd_w=HpxF7&pf_rd_p=75edadd2-86be-4ee5-8051-494ee8e3e65e&pd_rd_wg=Ho5az&pf_rd_r=CE0RGBK6SP0EBB3BV1JP&pd_rd_r=4e7ff003-db7b-451f-b829-38af3a357630
Is the device listed in Device Manager?
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
Nope
-= Topics Merged =-
Do not repost topics.
Reputation is a Lifetime to create but seconds to destroy.
 CHRISTIAN MEMBER
4 hours ago, SansVarnic said:
S-Sowwy sir
Do you mean you can get internet connectivity via ethernet?
My first suggestion is take a known working device from another computer and try it on yours, or alternatively, install you wifi adaptor into another machine and check it works.
Otherwise i think you have a dodgy installation and should do a fresh install if the hardware is working but you go no wifi.
As an aside, "S-Sowwy sir"  No.... just ... no.
Prototype Engineer - Oxford Hackspace
