Hi,
I want to build a new PC. Picking parts is a lot of fun but now Im stuck between the ryzen7 5800x and the core i7 11700kf. I checked a lot of benchmarks but I really wanna know what these two can really do per sec. So if i would just compare boost clockspeed the i7 11700kf would clearly win but the IPC is influencing this too. But I cant find anything about the IPC of these CPUs. Does anyone know how to get these informations?
https://linustechtips.com/topic/1429371-comparing-cpus-with-ipc/
5 minutes ago, xarmec said:
Hi,
Puget Systems use standardized testing.
https://www.pugetsystems.com/labs/articles/12th-Gen-Intel-Core-CPU-Review-Roundup-2248/
Unless you're looking for an exact IPC number. That's going to be extremely difficult to find.
https://www.techspot.com/article/2143-ryzen-5000-ipc-performance/
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
1 minute ago, xarmec said:
Hi,
You can't.
It is very hard to perform an IPC comparison, because the internals of an AMD CPU is different from an Intel CPU.
The best you can do is (what I can think of right now):
  • Both CPU clocked the same, NO boosting up or down (i.e. 4.0 GHz flat)
  • Exact same memory kit, running at the same frequency + timings
  • Same GPU, PSU, SSD/HDD, Cooler.
But nobody does that....
Reviews basically compares them at "out-of-the-box" configuration.
So the CPU will boost up/down on it's own.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
6 minutes ago, --SID-- said:
First question that comes in my mind; why 11700KF instead of 12600K(F) or 12700K(F)?
Indeed, the 11700K makes no sense compared to 12600K...
If you're wanting to get the more IPC possible either get a 12600K or better, they're faster than Ryzen 5000s
17 minutes ago, xarmec said:
mostly gaming. and a bit discord, chilling in streams and office stuff
i'd rather have a 12600k than a 11700k for that
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
I use Pass Mark single thread bench scores to get a good idea were a CPU stands.  https://www.cpubenchmark.net/singleThread.html
IPC is very important with my modded games since my i7 8086k and i9 9900k(5ghz all cores) are a stuttering mess playing them but are fine with vanilla games.
My 5800x played them smoothly as well as my 5900x, i9 10900k and i9 11900k.
I would not get an i7 11700k since it does not support TVB(thermal velocity boost). This allows the CPUs like the i9 11900k to hit 5.3ghz while staying below 70c. This smooths out most rough spots in games. It does not help with any all core benches.
I would get a 5800x.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
The 5800X3D is currently the best/fastest Ryzen cpu for gaming. There won't be much difference between the 5700X and 5800X. Also 4K gaming pretty much levels things out apart from the odd game. If you are gaming at 1080p/1440p then there will be a bigger gap between the 5800X3D and 5700X/5800X.
As for Intel a 12700/F and B660 board is a better option than 11th gen.
If you can't go with a 12600K or 12700K for some reason, then I'd go with the 5800X (or a 5700X if you have one available in your area for cheaper than the 5800X). The performance between the 5800X and the 11700KF are almost identical, with a slight edge to the 5800X, but the biggest advantage is with the platform.
Intel socket 1200 (400 and 500 series boards supporting 10th and 11th gen) is a terrible platform. I can't say it was the worst platform Intel ever released for sure, but it's up there. You have no upgrade path beyond the 11700KF - the 10900K loses PCIe Gen 4, and the 11900K is just the same CPU with a slightly better binning - so once you're there, you're done. The only option is a total platform upgrade.
Whereas, at least with a 5700X or 5800X, you have options to go from there thanks to the excellent AM4 platform. The Ryzen 9 5900X or 5950X offers you more cores, and the 5800X3D offers much better gaming performance. They are actual upgrade paths that can give your computer more life down the road if you can afford to get a used Ryzen chip, but can't yet afford a full platform upgrade.
