I've been having overheating problems for about 2 weeks. Whenever I boot up and go into bios my CPU temp is already at 60°+
I've already tried reapplying thermal paste and reseating both the CPU and cooler(this is on a completely new CPU and MOBO)
Is there anything that could be causing my cpu to be overheating?
The only reused components would be the GPU and then boot drive.
https://linustechtips.com/topic/1429342-overheating-problem/
1 minute ago, FukoG said:
I'm using a Ryzen 5900x with an MSI mag core liquid 360r
Is this one of the MSI coolers that got recalled because of the gunk buildup in the block? (Honestly asking for someone to say because I don't remember what models were affected.)
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1429342-overheating-problem/#findComment-15383817
Yes, yes it is.
Try and get that cooler replaced, odds are it's defective.
https://linustechtips.com/topic/1429342-overheating-problem/#findComment-15383821
Yes it is. @FukoGReturn it and get a better AIO.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1429342-overheating-problem/#findComment-15383822
@FukoG This is what we're talking about:
https://linustechtips.com/topic/1429342-overheating-problem/#findComment-15383824
Just adding this since the OP does have the link to the MSI recall page.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1429342-overheating-problem/#findComment-15383835
