5800x3d running hot?
morytox
Hi Community,
i recently changed out my 3900x to an 5800x3d. After i finished my build i noticed thermal ghrottling in 3dMark, even hitting 90 degree celsius in Guildwars2… I had a 2-3 Jears old Coolermaster ML360rgb. Maybe it was not that fit anymore, so i got a EK-AIO 360 and replaced it. Temps got a bit better but still scraping 90 in 3D mark and hitting high 80s in gw2. Thats strange in my opinion. Idle is 30-40, and 60ish under light browser/app opening load..
short my system:
gigabyte x570 aorus master
4x16gb Tridentz 3600
Gigabyte 3080ti master
lianli o11d
3x 120mm intake side
3x 120mm exhaust with radiator
i upgraded cpu and graphics at once, so probably there is more heat in the case right now. Rad in exhaust is sub-par here as well, but i could not manage to install it on the side with rubes on bottom due to lack of tubinglength.
are those temps in this instance a normal thing, or do i have other probs here?
I.e. pasting air bubble (had to invert positioning after initial mounting  zo no ram clearance)
or maybe higher voltage to some default mainbord cpu settings?
sorry for this long text, but i wanted to include as much debug info as possible.
What power profile are you running in Windows? Have you already tried clearing the CMOS to remove any motherboard settings that might be causing non-stock behavior?
so you're saying the CPU is only hot during times where gpu is also stressed?
what about cinebench/cpu only tests?
If you are using a 3080ti and the CPU as exhaust, you're cooling the CPU with hot air.
Generally speaking, radiator as intake = better for the component being cooled, worse for the things behind it. In this case, worse for the CPU. You could try mounting the AIO in intake configuration, and CPU temps will likely improve but gpu temps might suffer slightly.
I run my CPU aio as intake.
I'd also recommend double checking thermal paste application and mounting pressure. Also as above, follow youngblade's advice.
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
Sounds to me like you need more fans in your case
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
Do I have this correctly that the CPU AIO is the only exhaust flow in the system? If it's the sole method of exhausting GPU heat, it will suck. Especially when that GPU is creating 350w+ of waste heat. Might want to find some more ways to get exahust going.
My personal system is:
3x120 front intake
3x120 side intake (aio)
3x120 top exhaust
1x120 rear exhaust
GPU and CPU temps are pretty okay with both being modestly overclocked.
AIO should be intake.
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
The first question overall is: is it stock behavior or not? I have nothing to copare with yet
It depends on your setup and case
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
