Current build plus upgrades compatible?
1 minute ago, DoMx97x said:I’ve just recently upgraded my monitor to a G2 series AOC 1440p and the game I mostly play is COD mp and WZ .. I know it’s a demanding game and probably just server game restriction issues but I never seem to surpass the 90fps mark I’ve cleared all cache and I’m needed programs and I was hoping CPU and RAM upgrades would help or at least lessen the strain what other suggestions . P.s I’m knew to pc and all the tech “lingo” so please keep it as simple as possible
Upgrading a CPU isn't gonna change this. Check your settings and take it easy on anti-aliasing. You're correct in that's it's probably something other than your computer, as that game will usually run at over 170fps on a 6700xt, which is slower than your 3070. The CPU is in no way, shape, or form the issue. Your computer is probably totally fine. Your GPU and monitor are the limiters of your framerate, you'd need to have WAY slower CPU and RAM for that to be an issue. If it's stuck at exactly 90 it might be something in either your nVidia settings, the game settings, game code, or server settings.
Bottom line, though, put away your credit card, buying all this won't change anything.
