So my "USB 3" external DVD drive died
kennethk
The RW part stopped working on my USB external DVD drive the one time I actually needed it, out of curiosity I took it apart come to find it's being powered by a mini USB control board, can this even be considered USB 3 by using a mini USB control board or did china just lie to me?
That's how all of them essentially work. You have a USB to SATA adapter and the drive itself is connected via SATA.
wel.. if you wonder if it's usb 3.0 -- does it actually have more than 4 connection points in the usb connector?
ps: i love the huge label over the 'obviously an off the shelf sata slim DVD drive' saying it's defenately a usb drive 😄
I would've figured you'd at least need micro usb to achieve the USB 3 title 🤷‍♂️
There is no USB3 external optical drive that I know of, the fastest DVD drive there is won't even saturate USB2 (16x is just 20MB/s) so it's pointless to use a more expensive USB3 adapter board. A fast internal blu-ray drive could benefit but it's likely a "laptop" drive won't even read one fast enough either anyway.
So yeah they'll have lied to you as in "works with a USB3 port". Or they did mention USB3 because you should use a USB3 port just for the higher power supply ability.
F@H
GPD Win 2
It wouldn't really matter even if it did use a USB 3 controller. A laptop optical drive like that won't be fast enough to need more than a USB 2 connection.
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
Fooled again by the blue connector.
More then likely that since the USB2 Asus external DVD drive I have requires 2 USB ports more then likely because one connector can't supply all the power the drive needs.
