LED/RGB Help.
AndyJay
So I've always hated the lights on computers but on my new build a few months back I took a dive and went for it, but I'm having issues with the different manufacturers and getting the RGB to sync up. This is my last ditch effort before just ignoring it.
Here's a break down of my stuff with RGB:
  • Case - Cooler Master MasterBox TD500 Mesh includes 3 x ARGB Fans
  • Cooler - Corsair iCUE H100i ELITE CAPELLIX  (I think this included some sort of commander core)
  • GPU - MSI 3060 TI Gaming Trio LHR 8GB (Aura Sync)
  • MOBO - Asus X570 TUF Gaming w/ Wifi
  • Ram - 2x16GB G.Skill Trident Z Neo
Now I can control
  • GPU and mobo through Mystic light on the MSI Center
  • The AIO cooler separately with iCue. If I close MSI Center iCue then detects my mobo, but I can only change the mobo rgb which doesn't alter the GPU, ram or case fans.
  • Armoury crate aura sync to control case fans, ram & mobo rgb.
I have tried following multiple videos to get stuff working on iCue but I can't seem to do it. I am now suspecting there's some sort of incompatibiltiy issue with where these fans/rgb headers are plugged in to.
Is there anything I can do or purchase to plug everything into one?
Are you plugging the fans that came with the cooler master into the commander core? Or into the MB?
you can try theses
JackNet RGB Sync:
1
1
OpenRGB:
1
1
signalrgb
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
The fans that came with the pc are plugged into the mobo. If I remember correctly the pins were different and wouldn't fit into the commander core
ya you would need an adapter to attach em to it.
