You could perhaps try reseating the wifi card on the motherboard
Minecraft plugin developer
Desktop:
CPU= I5 12400F
RAM = 2x 32gb DDR4 3200MHZ Corsair Vengeance LPX
Motherboard = MSI Z690-A-PRO Wifi DDR4
GPU= RTX 3050
SSD = Samsung 980 Pro 1TB
PSU= Corsair RM750
Laptop:
CPU= AMD Ryzen 5 5500u
RAM= 1X 4gb (soldered 3200mhz), 1x 16gb ddr4 3200mhz (so-dimm)
SSD= Samsung 970 Evo 1TB
https://linustechtips.com/topic/1425793-wifi-card-replacement/#findComment-15358632
2 hours ago, flaxe said:
If you have any available USB ports, you can use a wifi adapter.
No, just no, absolute last resort.
https://linustechtips.com/topic/1425793-wifi-card-replacement/#findComment-15358925
