CPU not boosting to rated frequency
Solved by RONOTHAN##,
It's not uncommon for a 3000/5000 series Ryzen CPU to not hit its max boost speed, that max boost is only under perfectly ideal conditions. If temps are a little too high (say you're using the stock cooler), more than one thread is being used at all, or a number of other factors the CPU won't hit its max boost.
My 5900X for example is rated for 4.8GHz max boost, I've yet to see it go above 4.7 in anything I actually do with PBO enabled. it's not uncommon.
