Maybe your power states got messed up in the BIOS.
Or it's just fans that keep on running.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
Reset CMOS, take CMOS battery out as well as turning the computer off at the wall for 30 seconds or longer then put the battery back in first then turn the power back on at the wall and turn it on. Then test the PC without making any changes to the BIOS. If it still does the same thing check to see if anything like "Keep awake" is switched on in the BIOS.
System Specs:
CPU: Ryzen 7 5800X
GPU: Radeon RX 7900 XT
RAM: 32GB 3600MHz
HDD: 1TB Sabrent NVMe -  WD 1TB Black - WD 2TB Green -  WD 4TB Blue
MB: Gigabyte  B550 Gaming X- RGB Disabled
PSU: Corsair RM850x 80 Plus Gold
Case: BeQuiet! Silent Base 801 Black
Cooler: Noctua NH-DH15
You mean by flashing the BIOS to a previous version?
No.
Look for one of those on your motherboard, take it out and leave it out while your PC is turned off at the wall for 30 seconds or longer then put the battery back in and then turn the computer back on.
System Specs:
CPU: Ryzen 7 5800X
RAM: 32GB 3600MHz
