Been wondering why my Trinitron Ultrascan 15 has been making crackling/popping noises for a while (occasionally distorting the picture while it happens). Accidentally came across a Reddit post this morning by someone with a similar Multiscan monitor, said it crackled, popped, then released the magic smoke that draws the pixels eventually (and all the replies say it's flyback related).
I would like to replace mine before anything gets worse. I don't have extensive experience with CRT repair in particular but I've worked on 90s home electronics and a couple smaller, much less advanced CRTs. Seen some YT videos on replacing flybacks and that seems like quite a lot of pins to desolder.
Do you recommend I try and find another flyback (they can get over $100 for the better ones) or sell it for not too expensive to someone who can repair it? Could also recycle it or sell for scrap but I'd rather not, the tube is in pretty good shape and doesn't show many signs of degradation although it is likely rather high hour. (Oh I might want to mention - it also has a strange problem where it'll stop displaying red, only green and blue work, when the cable is at a certain angle but I'd assume that's more a problem with the permanently attached VGA cable, the red gun works fine otherwise)
And if I do want to replace it myself where should I look for a flyback? Just ebay? Maybe look in the service manual for part numbers? Monitor model is D1526TX-HS, of the UltraScan 15TX series.
Any help would be appreciated!
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/1424733-finding-replacement-crt-flyback/
36 minutes ago, Monkey Dust said:
CRTs hold high voltages in them for a long time after being switched off. They aren't DIY friendly, they are properly dangerous when you open them up, and it really should be left to someone who knows what they are doing.
I’m aware of that and I can properly discharge it, my main question was finding a replacement transformer.
Works Cited
