_______________________________________________________________________________
Welcome to another build, this build will encompass the beauty of water and ice together, in a water-cooling build. This build will be focused on aesthetics and performance, demonstrating the power of the GTX 780, while showing off the cool blue glacier interior.
This will be a white and blue theme with custom modding to the side panel window as well as any removal of drive bays in order to get as functional and clean of a look as possible.
Link to the original build log - http://www.overclock.net/t/1478352/build-log-project-glacier-gtx-780-o-c-i5-4670k-o-c-water-cooled-xs-pc-raystorm
Main Components:
  • Case - Thermaltake Commander MS-I Snow Edition
  • Motherboard - Gigabyte Z87X-D3H
  • CPU - Intel i5-4670k
  • Graphics Card - Zotac GeForce GTX 780
  • Power Supply - Corsair Professional HX850W
  • Ram - Corsair Vengeance Pro Blue
  • Hard Drive (SSD) - Kingston HyperX 3K 120GB
  • Hard Drive SATA - 1tb Western Digital
  • Tubing - XSPC FLX Premium Grade PVC Tubing - 1/2" ID (3/4"OD)
  • Fittings - Low compression silver fittings 1/2" ID 3/4" OD
  • Coolant - Mayhems pastel blue berry
  • Llighting - 3x' White Rigid LED Lighting Strips & XSPC blue&white LEDs
  • Radiator - BLACK ICE SR-1 140mm
  • Reservoir - XSPC Dual Bay Reservoir + DDC pump
  • Fan Cooling - 2x's 120mm + 4x's 140mm cougar blue LED
  • Optical Drive - LG DVD RW
  • Big Window Mod | component & case painting | HDD cage removal & more!
Full Log on Overclock.net http://www.overclock.net/t/1478352/build-log-project-glacier-gtx-780-o-c-i5-4670k-o-c-water-cooled-xs-pc-raystorm
<img>http://www.overclock.net/content/type/61/id/1960232/</img>
<img>http://www.overclock.net/content/type/61/id/1960233/</img>
<img>http://www.overclock.net/content/type/61/id/1960234/</img>
<img>http://www.overclock.net/content/type/61/id/1960235/</img>
<img>http://www.overclock.net/content/type/61/id/1960236/</img>
<img>http://www.overclock.net/content/type/61/id/1960237/</img>
<img>http://www.overclock.net/content/type/61/id/1960238/</img>
<img>http://www.overclock.net/content/type/61/id/1960239/</img>
<img>http://www.overclock.net/content/type/61/id/1960240/</img>
<img>http://www.overclock.net/content/type/61/id/1960241/</img>
<img>http://www.overclock.net/content/type/61/id/1960242/</img>
<img>http://www.overclock.net/content/type/61/id/1960243/</img>
<img>http://www.overclock.net/content/type/61/id/1962028/</img>
<img>http://www.overclock.net/content/type/61/id/1962030/</img>
<img>http://www.overclock.net/content/type/61/id/1962031/</img>
<img>http://www.overclock.net/content/type/61/id/1962032/</img>
<img>http://www.overclock.net/content/type/61/id/1962033/</img>
<img>http://www.overclock.net/content/type/61/id/1962034/</img>
<img>http://www.overclock.net/content/type/61/id/1962035/</img>
<img>http://www.overclock.net/content/type/61/id/1962037/</img>
<img>http://www.overclock.net/content/type/61/id/1962051/</img>
<img>http://www.overclock.net/content/type/61/id/1962039/</img>
<img>http://www.overclock.net/content/type/61/id/1962040/</img>
<img>http://www.overclock.net/content/type/61/id/1962042/</img>
<img>http://www.overclock.net/content/type/61/id/1962043/</img>
<img>http://www.overclock.net/content/type/61/id/1962044/</img>
<img>http://www.overclock.net/content/type/61/id/1962045/</img>
<img>http://www.overclock.net/content/type/61/id/1962046/</img>
<img>http://www.overclock.net/content/type/61/id/1962047/</img>
<img>http://www.overclock.net/content/type/61/id/1967038/</img>
<img>http://www.overclock.net/content/type/61/id/1967039/</img>
<img>http://www.overclock.net/content/type/61/id/1967040/</img>
<img>http://www.overclock.net/content/type/61/id/1967041/</img>
<img>http://www.overclock.net/content/type/61/id/1967042/</img>
<img>http://www.overclock.net/content/type/61/id/1967043/</img>
<img>http://www.overclock.net/content/type/61/id/1967044/</img>
<img>http://www.overclock.net/content/type/61/id/1967045/</img>
<img>http://www.overclock.net/content/type/61/id/1967046/</img>
<img>http://www.overclock.net/content/type/61/id/1967047/</img>
<img>http://www.overclock.net/content/type/61/id/1967048/</img>
<img>http://www.overclock.net/content/type/61/id/1967049/</img>
<img>http://www.overclock.net/content/type/61/id/1967050/</img>
<img>http://www.overclock.net/content/type/61/id/1967051/</img>
<img>http://www.overclock.net/content/type/61/id/1967053/</img>
<img>http://www.overclock.net/content/type/61/id/1967054/</img>
<img>http://www.overclock.net/content/type/61/id/1967055/</img>
<img>http://www.overclock.net/content/type/61/id/1967056/</img>
<img>http://www.overclock.net/content/type/61/id/1967057/</img>
<img>http://www.overclock.net/content/type/61/id/1967058/</img>
<img>http://www.overclock.net/content/type/61/id/1967059/</img>
<img>http://www.overclock.net/content/type/61/id/1967060/</img>
<img>http://www.overclock.net/content/type/61/id/1967061/</img>
<img>http://www.overclock.net/content/type/61/id/1967062/</img>
<img>http://www.overclock.net/content/type/61/id/1967063/</img>
<img>http://www.overclock.net/content/type/61/id/1967064/</img>
<img>http://www.overclock.net/content/type/61/id/1967065/</img>
<img>http://www.overclock.net/content/type/61/id/1967066/</img>
<img>http://www.overclock.net/content/type/61/id/1967067/</img>
<img>http://www.overclock.net/content/type/61/id/1967068/</img>
<img>http://www.overclock.net/content/type/61/id/1967069/</img>
<img>http://www.overclock.net/content/type/61/id/1970701/</img>
<img>http://www.overclock.net/content/type/61/id/1970703/</img>
<img>http://www.overclock.net/content/type/61/id/1970705/</img>
<img>http://www.overclock.net/content/type/61/id/1970706/</img>
<img>http://www.overclock.net/content/type/61/id/1970707/</img>
<img>http://www.overclock.net/content/type/61/id/1970708/</img>
<img>http://www.overclock.net/content/type/61/id/1970710/</img>
<img>http://www.overclock.net/content/type/61/id/1970711/</img>
<img>http://www.overclock.net/content/type/61/id/1970920/</img>
<img>http://www.overclock.net/content/type/61/id/1970921/</img>
<img>http://www.overclock.net/content/type/61/id/1970922/</img>
<img>http://www.overclock.net/content/type/61/id/1970923/</img>
<img>http://www.overclock.net/content/type/61/id/1970924/</img>
<img>http://www.overclock.net/content/type/61/id/1970925/</img>
<img>http://www.overclock.net/content/type/61/id/1972255/</img>
<img>http://www.overclock.net/content/type/61/id/1972256/</img>
<img>http://www.overclock.net/content/type/61/id/1972257/</img>
<img>http://www.overclock.net/content/type/61/id/1972258/</img>
<img>http://www.overclock.net/content/type/61/id/1972259/</img>
<img>http://www.overclock.net/content/type/61/id/1971222/</img>
<img>http://www.overclock.net/content/type/61/id/1971223/</img>
<img>http://www.overclock.net/content/type/61/id/1971224/</img>
<img>http://www.overclock.net/content/type/61/id/1971225/</img>
<img>http://www.overclock.net/content/type/61/id/1971226/</img>
<img>http://www.overclock.net/content/type/61/id/1971227/</img>
<img>http://www.overclock.net/content/type/61/id/1972287/</img>
<img>http://www.overclock.net/content/type/61/id/1972288/</img>
<img>http://www.overclock.net/content/type/61/id/1972289/</img>
<img>http://www.overclock.net/content/type/61/id/1972290/</img>
<img>http://www.overclock.net/content/type/61/id/1974871/</img>
<img>http://www.overclock.net/content/type/61/id/1974872/</img>
<img>http://www.overclock.net/content/type/61/id/1974873/</img>
<img>http://www.overclock.net/content/type/61/id/1974874/</img>
<img>http://www.overclock.net/content/type/61/id/1974875/</img>
<img>http://www.overclock.net/content/type/61/id/1974876/</img>
<img>http://www.overclock.net/content/type/61/id/1974877/</img>
<img>http://www.overclock.net/content/type/61/id/1974878/</img>
<img>http://www.overclock.net/content/type/61/id/1974879/</img>
<img>http://www.overclock.net/content/type/61/id/1974880/</img>
<img>http://www.overclock.net/content/type/61/id/1974881/</img>
<img>http://www.overclock.net/content/type/61/id/1974882/</img>
<img>http://www.overclock.net/content/type/61/id/1974883/</img>
<img>http://www.overclock.net/content/type/61/id/1974884/</img>
<img>http://www.overclock.net/content/type/61/id/1974885/</img>
<img>http://www.overclock.net/content/type/61/id/1974897/</img>
<img>http://www.overclock.net/content/type/61/id/1974904/</img>
<img>http://www.overclock.net/content/type/61/id/1974906/</img>
<img>http://www.overclock.net/content/type/61/id/1974907/</img>
[spoiler=Filling The Loop Mayhems Blue Berry ;)]
<img>http://www.overclock.net/content/type/61/id/1975251/</img>
<img>http://www.overclock.net/content/type/61/id/1975252/</img>
<img>http://www.overclock.net/content/type/61/id/1975253/</img>
<img>http://www.overclock.net/content/type/61/id/1975290/</img>
<img>http://www.overclock.net/content/type/61/id/1975291/</img>
<img>http://www.overclock.net/content/type/61/id/1975292/</img>
<img>http://www.overclock.net/content/type/61/id/1975293/</img>
http://www.overclock.net/content/type/61/id/1976378/</img>
<img>http://www.overclock.net/content/type/61/id/1976379/</img>
<img>http://www.overclock.net/content/type/61/id/1976380/</img>
<img>http://www.overclock.net/content/type/61/id/1976381/</img>
<img>http://www.overclock.net/content/type/61/id/1976382/</img>
<img>http://www.overclock.net/content/type/61/id/1976383/</img>
<img>http://www.overclock.net/content/type/61/id/1976384/</img>
<img>http://www.overclock.net/content/type/61/id/1976385/</img>
<img>http://www.overclock.net/content/type/61/id/1976386/</img>
<img>http://www.overclock.net/content/type/61/id/1976387/</img>
<img>http://www.overclock.net/content/type/61/id/1976388/</img>
<img>http://www.overclock.net/content/type/61/id/1976391/</img>
<img>http://www.overclock.net/content/type/61/id/1976392/</img>
<img>http://www.overclock.net/content/type/61/id/1976393/</img>
<img>http://www.overclock.net/content/type/61/id/1976394/</img>
<img>http://www.overclock.net/content/type/61/id/1976395/</img>
<img>http://www.overclock.net/content/type/61/id/1976396/</img>
<img>http://www.overclock.net/content/type/61/id/1976397/</img>
<img>
Video Build Log From Start To Finish
https://linustechtips.com/topic/142415-project-glacier/
so many links, but looks great
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/142415-project-glacier/#findComment-1901035
Instead of using html, simply use the picture frame icon in the toolbar and put the img source url there. ;D
LOL I know that but unfortunately when you use a link on another forum it doesnt automatically generate the *.jpg url so you have to have it generated then enter the .jpg... ugh this is a pain LOL
https://linustechtips.com/topic/142415-project-glacier/#findComment-1901068
Some sleeved cables would complete this entirely, but good job
Intel i7 4770k @4.5ghz, Asus Maximus VI Formula, Asus Geforce GTX 780, Corsair h100i, Corsair Neutron GTX 240gb, WD Black 1tb, Corsair 750D, Corsair AX860i w/ Sleeved Cables.
I rarely leave the build logs section.
https://linustechtips.com/topic/142415-project-glacier/#findComment-1902453
That is a very nice rig. And also some very nice photo's. What camera did you use?
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/142415-project-glacier/#findComment-1902563
Q1: I am also going to be making a similar type of colour scheme (with added black) I was hoping to paint the backplate also, may I ask the process and method on how you painted the GPU backplate?
Q2: Does this backplate fit on any reference design GTX 780?
 This is amazing ._. Kudos to you Sir!
Edit: Also the process on how you painted the rads :) <3
Current Build: Case: Define R4 White/Window CPU: i5 3470 @4.0Ghz GPU: GTX 680 DCUII +500Mhz(Mem) Cooler: Hyper 212 EVO Monitor: Acer Monitor 1920x1080 MOBO: Asrock Z77 Extreme 4 Storage: 2TB HDD, 120GB 840 EVO (OS)
Future Build: 4670K, GTX 780 MSI TwinFrozr OC, Z87X-D3H, 8GB @1866Mhz, 120GB SSD, 1TB HDD, 750D, RM 650W, Custom Loop. White/Blue/Black Colour Scheme. I literally cannot wait *_*
https://linustechtips.com/topic/142415-project-glacier/#findComment-1902669
Nice job :) I am also a user of the pastel coolant (in red)  ^_^
Thanks yea this is my first time using pastel and liked the outcome, the blue is a nice light blue (glacier like ;)
Looks nice :) I can never get away with a blue and white color scheme...
Very clean and professional, looks awesome!
Thank you I really try to pay attention to the details that matter, like the painting of the backplates, and I/O sheilds etc, it really changes the build :)
Unfortunately this was under a budget for a client so I couldnt go all out, as well the cable management in this small form factor case was truly a miracle that I got it closed! LOL This case is alot smaller and leave no room for cable management. A non-modular PS requires alot of cable management, and that I had to do indeed ;)
I used my sisters camera at the end of the build, it is a very expensive camera, and I will be purchasing one not as pricy but loved the manual focus and lenses.
A1) painting the backplate, along with anything in a build (please see the video) but takes around 3-4 light coats of paint of your desire, after this layer by layer (dont spray to close otherwise it will clog up and create bubbles and drip) at which point you will need to take a fine gritt sandpaper and smooth off the paint you have done then re-do it.
When painting there is never really any fear of screwing up because you can just wait for it to dry, then sand it down with 1000/2000 gritt sandpaper and re-apply another coat of paint until you have it just right.
Once you are satisfied with the pain you MUST apply a clear Lacquer, this protects the paint from scratches, as well puts a coat of gloss (or you can get no gloss) over your paint job and really pulls out the color in the paint. You should do 2-3 thick coats of this lacquer and let dry.
The rad painting you need to tape off the fins
then you can spray to your hearts desire, the rad is the same if you see build up, you can sand it down and do it again no big deal if you screw up with paint :)
A2) Yes this backplate is just a reference 780 backplate I painted white
So thank you all for your comments I'd love to hear more and you can check out all the mods I had to do in my video above :) as well it was voted for mod of the month on overclock.net, so if you really felt in a giving mood you could vote for me  :)LOL :D
https://linustechtips.com/topic/142415-project-glacier/#findComment-1903163
