Hello everybody, Trevor again... thanks for your help, it really seriously helped me. I need more help. I need 2 monitors (2k-3k should be fine), A keybord for gaming (mechanical preferably), A  gaming mouse (one that matches with the keybord), A computer case (Corsair OP Prefers), L.E.D. strips (multicolored), the best 120 gb ssd (for kali linux and windows 8.2 pro) ,  and a gpu cooler for a radeon r9 290x vid card.
If Anyone can help, Id GREATLY appreciate it.
https://linustechtips.com/topic/142308-need-help-again/
K95 keyboard
M95 mouse
obsidian 750D or graphite 760T
NZXT Hue RGB LED strip
samsung 840 pro or evo 120GB SSD
https://linustechtips.com/topic/142308-need-help-again/#findComment-1899823
K95 keyboard
M95 mouse
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/142308-need-help-again/#findComment-1899868
K95 keyboard
M95 mouse
I would switch the K95 and M95 for a K70 and a M65 if you don't play mmo's and you like it more fpsy. having the k70 and m65 myself and I love them.
it's time for some jolly cooperation!
https://linustechtips.com/topic/142308-need-help-again/#findComment-1899891
Keyboard: Corsair K70
http://www.newegg.com/Product/Product.aspx?Item=N82E16823816021
Mouse: Mionix Naos 8200 (Has an RGB LED)
http://www.newegg.com/Product/Product.aspx?Item=N82E16826580004R
Case: Corsair Obsidian 750D
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139024
SSD: Intel 730 Series 240GB (I really recommend more than 120GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167190
Monitor (x2): ASUS VG248QE 24" 144Hz 1080p monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236313
LED Strips: Bitfenix Alchemy 30cm
http://www.newegg.com/Product/Product.aspx?Item=N82E16811997048
Note: Newegg isn't the cheapest place to find these parts, this was only to show approximate pricing
https://linustechtips.com/topic/142308-need-help-again/#findComment-1900008
but the k95 is so much more luxurious! its not about the buttons, but about the black aluminum construction, wrist rest, white backlight...
the m95 is also more comfortable cause its a single piece unlike the m65
obviously these are more expensive than the 65, but i still really like my k95 and m90
https://linustechtips.com/topic/142308-need-help-again/#findComment-1900070
Unless i'm mistaken, i'm on my k70 and it comes in black aluminium as well, with a wrist rest too. only difference is red backlight.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/142308-need-help-again/#findComment-1901164
yeah, or gunmetall aluminium, wrist rest, blue backlight and textured extra keys on my k70 with mx blues . the three m65 pieces feel like one.
https://linustechtips.com/topic/142308-need-help-again/#findComment-1901816
