With my system will a 4k 144hz monitor even benefit me?
Just now, TexasBulldog74 said:Gotcha. I keep up with PC components pretty good but the movement and tech increases in monitors is something i don't really follow.
I think my issue with this monitor is when I edit photos (armature photographer with a paid gig every now and then) the images just don't look good but then i'll see them on my laptop and its gorgeous. its just strange. Its been great in the gaming world but i think the problem is im looking for a best of both worlds solution but i don't know what monitor that would be, if that even exists.
When you do go to upgrade, I would probably try and go for a 4K 144Hz panel. A lot of the IPS ones out there really are beautiful (I personally really enjoy my Aorus FI32U, it's pretty color accurate and a great gaming display, but I'm not a photographer with the closest thing I've had to photo editing being MS Paint so take that with a grain of salt) and should make a pretty good photo editing by day/gamer by night monitor. It's just that if you can just edit photos on your laptop for the time being and upgrade your monitor when you upgrade your GPU that would be what I do.
Either that or go dual monitor setup, professional 4k 60Hz high color space panel for photo editing/content consumption and keep using your MSI monitor for gaming. If you have the desk space for it that would be the best of both worlds, you can keep gaming on a relatively easy to drive monitor with a high refresh rate yet have all the benefits of a professional monitor with just more screen real estate in general (2 monitors is infinitely better than 1 for anything professional).
