I just need help to choose (GTX 970 or RTX 2060 for host/VM?)
Didrik
I am setting up a linux pc with two gpus. One is a GTX 970 and the other is a RTX 2060. One of these will be for a VMs and the other for the host.
I just cant decide on which.
I will be mainly in the host, and try to game mostly in the host.
thanks for any recommendations.
(And sorry if this is in the wrong category)
CPU: AMD Ryzen 9 5900X
MB: Gigabyte Aorus Ultra Gamming X470
GPU: ASUS ROG GeForce RTX 2060 Advanced ed
RAM: 4x8 DDR4 G.skill TridentZ 3000Mhz
Cooler: bequiet! Dark Rock Pro 4
OS Drive: PNY CS3030 1TB
Case: bequiet! Dark Base 900 PRO Rev2.0
PSU: XFX PRO 850W XXX 80+ Bronze
My Steam Profile (from SteamDB)
  • Value: $3161 ($1003 with sales)
  • Games owned: 366
  • Games played: 293 (80%)
  • Hours on record: 9,679.5h
You dont need a GPU for a VM. What exactly is the reason you are looking to assign a GPU to vm? Considering both are Nvidia GPUs, use the one you feel like it.
For fun and more graphic intensive tasks.
  • Games owned: 366
did you want to explain or elaborate on that or are you using two gpu's for basically no articulable reason
wouldn't you like to now ( ͡° ͜ʖ ͡°)
  • Games owned: 366
Yes, that is how questions work.
Also, it is information that helps folks here answer yours...
In that case I'd use the faster/more modern GPU on the host and the other one for the VM. If you're not doing anything in the VM that requires 3D acceleration (or only occasionally), no real need to bind the faster GPU to it.
