Cooling 5950x is a problem for me, please help good people! ;)
Solved by TaiwaneseGuy11,
12 hours ago, WoodenMarker said:What's the temp difference with front / side panels removed?
Actually by removing side and front panel I didn't get any significant difference. But what I found is the weak spot of this @#$% case top panel, removing it makes pc 6 С cooler.
12 hours ago, Shimejii said:82-85 is honestly fine. You would need to get a different case or just have different room temps or a completely different case.
Big thanks guys @Shimejii @WoodenMarker @An0maly_76 for stopping by . I found a cool solution, maybe it is obvious for you guys though. I transfered OBS Stream on second CCD with Process Laso. On 1st CDD Stream was always pushing high frequency marks. And my CPU after this change dropped to 67-66 even in this "bad" case for my tasks.
