CPU cooler?
Go to solution Solved by Newaroundhere,
2 hours ago, WoodenMarker said:
A Hyper 212 Evo can work but there are often better options. Where are you shopping / located? Budget?
What ram are you using and what are your priorities?
I'm using Amazon UK, Scan Computers and pretty much any reputable UK based business. I initially looked at £150 as I was considering the Kraken x63, my ram is 32 GB cl18 3600 Corsair RGB pro.
I prefer the looks of the x63 however, I just wanted to consider all options available.
Thank you
https://linustechtips.com/topic/1420910-cpu-cooler/#findComment-15324314
I bought a used Hyper 212 for a bargain price, you can also get the Vetroo V5 for similar cooling performance at a low cost.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1420910-cpu-cooler/#findComment-15324340
Thank you
https://linustechtips.com/topic/1420910-cpu-cooler/#findComment-15324477
The Kraken X63 is plenty for cooling and arguably overkill.
If you wanted to save a bit of money, the AS500 would be a good alternative with a similar mostly black / hint of rgb aesthetic. https://uk.pcpartpicker.com/product/cmH7YJ/thermaltake-toughair-510-5835-cfm-cpu-cooler-cl-p075-al12bl-a
https://linustechtips.com/topic/1420910-cpu-cooler/#findComment-15324579
