Yes, you can always run just one stick of RAM without issue. You will, however, take a performance hit due to it only being single channel. Two sticks in dual-channel will always be better.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
1 minute ago, Brando420 said:
can i use only one stick of cmk16gx4m2b3200c16 or do I need both
How do you mean that exactly? What do you use your system for? Generally you can run with one stick of RAM but two sticks in dual-channel mode does get you some better performance in games. Although not that much but it is an improvement
Thanks I was just wondering cause I got one guess I'll trying to get other one lol. Also want to build a gaming PC for the least amount of money I'm poor an am not above using 2nd hand of off brand parts I've found sum off brands performe better than name brand
