NH-D15 weird noise
Solved by Rainbrew,
So as an updated I re-positioned one of the fans of the NH-D15 a bit lower and added low noise adapters to both and while it is quieter the noise still persists. Can't do anything to the case to make it stop doing that so I'll contact noctua and be quiet and figure out if the case is funky or maybe one of the fans is vibrating abnormally.
I noticed that the case fans even at 100% experience no vibrations while the two CPU fans do vibrate at 50%+ but that may be due to the higher rpm so idk.
