Posted April 20, 2014 My dad's PC is quite loud, and we've narrowed the cause down to his 92mm exhaust fan. I have some options for what we can replace it with, and would appreciate your opinion on which would fit the bill the best; quietest without sacrificing too much performance. EDIT: You'll need the link, I guess. http://www.umart.com.au/pro/products_listnew.phtml?id=10&bid=5&id2=231 My Battlestation. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 20, 2014 Solution Arctic F9 PWM CO. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 20, 2014 Author Thanks, Wooden. My Battlestation. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 20, 2014 My dad's PC is quite loud, and we've narrowed the cause down to his 92mm exhaust fan. I have some options for what we can replace it with, and would appreciate your opinion on which would fit the bill the best; quietest without sacrificing too much performance. EDIT: You'll need the link, I guess. http://www.umart.com.au/pro/products_listnew.phtml?id=10&bid=5&id2=231 Any of the Noctuas are the best choice in terms of sound/performance, but they're expensive. The Fractal fans are surprisingly good, and the F9 is nothing to thumb your nose at. CPU-AMD FX 8350 @ 4.9Ghz | GPU-Sapphire 7970 OC | Motherboard-AsRock Extreme9 990fx | RAM-8GB Mushkin Blackline Ridgeback Case-NZXT Switch 810 | Heatsink-NZXT HAVIK | SSD-Samsung 840 250GB | HDD-Seagate Barricuda 1TB; WD Green 2TBPSU-Seasonic X-Series 850 Watt | Mouse-Razer Naga | Keyboard-Razer Blackwidow | Speakers-Logitech z623 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 21, 2014 My dad's PC is quite loud, and we've narrowed the cause down to his 92mm exhaust fan. I have some options for what we can replace it with, and would appreciate your opinion on which would fit the bill the best; quietest without sacrificing too much performance. EDIT: You'll need the link, I guess. http://www.umart.com.au/pro/products_listnew.phtml?id=10&bid=5&id2=231 If you have any other exhaust fans in the case, just get rid of the fan and have nothing there, it won't hurt temps that much (barely any actually ) CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 21, 2014 Author If you have any other exhaust fans in the case, just get rid of the fan and have nothing there, it won't hurt temps that much (barely any actually ) Aside from the stock intel heatsink, that's the only fan in the case at all. My Battlestation. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 21, 2014 Aside from the stock intel heatsink, that's the only fan in the case at all. oh, right yeah i'd say replace it then sorry i dont know any quiet 92mm fans though. CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 21, 2014 Author -snip- i dont know any quiet 92mm fans though. That's fine. I've advised dad to get the ArcticCooling F9 that WoodenMarker suggested. My Battlestation. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 24, 2014 Author Arctic F9 PWM CO. Dad just put the new fan into the case, and HOLY BALLS at the difference it's made. Aside from the fan on the stock intel heatsink spinning up, the case is damn near silent. Thank you so much for the advice. My Battlestation. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 24, 2014 Dad just put the new fan into the case, and HOLY BALLS at the difference it's made. Aside from the fan on the stock intel heatsink spinning up, the case is damn near silent. Thank you so much for the advice. Glad to see things worked out. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 24, 2014 have you thoght about the arctic freezer pro 7 v2? http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134 or maybe the cooler master hyper 212 evo http://www.amazon.com/gp/aw/d/B005O65JXI?pc_redir=1398203458&robot_redir=1 and you should think about mounting the fan on the cpu coller to a side in which it will blow air out of the case and the other fan as intake oh ive seen you allready got a sulotion. nevermind me Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
