If you have a lisence connected to your MS account, then acitvate and choose troubleshoot, and then recently changed hardware
You need to be logged into the MS account, and you will get the option to transfer the lisence
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
https://linustechtips.com/topic/1418908-need-help/#findComment-15310284
