Help finalising spec for NAS box
Solved by LionSpeck,
2 hours ago, Sally-san said:Is that enough memory and CPU power to handle the server? I read you need 1gig of ram per TB of data storage but then I read that it's out of date information and 8-32gigs is fine.
CPU wise I think you're fine for your usage. Don't expect to be running VMs or anything fancy down the line, though you should be fine with a bunch of containers.
As for RAM, ECC is recommended, but that'd be a change of platform. 16GB is the minimum but enough: still, the more the better, ARC will eat anything you give it.
