FIIO K5PRO or Schiit Hel 2E for gaming
krlos1823
im thinking about buying one of those two, im using sony mdr-1am2 and epos h6 pro mainly for my pc
which do you recommend?
Both will do. Get the cheaper one or the one that better suits your setup.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
i live in mexico and the price for both are the same, the both will work great with my setup
Imo for gaming due to the mic input I would go for the hel. But a nice possibly better alternative is the creative sound blaster x g6 or g5
It looks like your headphones are 16/28 Ohms. As such they're relatively easy to power. Unless you're having huge drops in sound quality at louder sound levels (and even then it's likely the headphones not the source, you're fine.)
You might be trying to solve a problem that doesn't exist. Usually it's MUCH better to spend more on the headphones than on the power source (especially for 16 Ohm headphones - these aren't 600 Ohm monsters)
Of those I'd probably lean towards the Schiit because it looks like it can work with microphones as well.
As an aside, I have a pair of HD800s (VERY HARD TO DRIVE, 300 Ohms so ~10x the resistance of your headphones). I have a Schiit Magni. The Magni is considered adequate for these headphones. I'm too lazy to plug it in and instead just plug my headphones into my AVR (which isn't BAD but it's not considered best practice) since it changes the sound over automatically.
3900x | 32GB RAM | RTX 2080
1.5TB Optane P4800X | 2TB Micron 1100 SSD | 16TB NAS w/ 10Gbe
QN90A | Polk R200, ELAC OW4.2, PB12-NSD, SB1000, HD800
Yeah about 10 times the resistance. But not 10 times as hard to drive or get them to where they sound good. Efficiency is also a big factor.
PM or DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
Beyerdynamic Tygr 300 R w/ Dekoni Velour as daily driver
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Keyboard > SteelSeries Apex Pro
Mouse > Steelseries Aerox 3 wireless
Mousepad > Pulsar ParaSpeed XXL
VR > Valve index kit
Read this post if you want a "gaming" headset ;)
YEAH but if i have a better amp/dac i can buy better headphones or a more variety ones, i have a hyperx mic usb so the mic is not really a problem, i just care about sound quality, but thanks for the suggestion.
I wouldn't worry about the future option to buy more headphones until you're actually considering that purchase in the future.
and for just audio quality?
I think the hel is pretty good. Just hard to recommend over a magni and atom dac. Or a atom stack.
Thanks, I suppose that the hi res in de fiio k5 doesn't really Matter?
Hi res stickers don't mean much to me is a detremnt cause it means the company spent extra to get hi res certification to have the right to use the sticker rather than jus using the money on better components. These days most great will pass hi res certification regardless of the sticker.
i see, thanks, yeah i will buy the hel
Either would work and I have to say that you don't even need either of them, you could save a buck and go for the schiit fulla or the fiio k3.  The only reason I would opt for one of the two you mentioned would be incase you want to future proof for harder to drive headphones.  An anecdotal comment is that schiit product's are a touch brighter and a touch lower in bass, at least compared to my topping.  I had a schiit stack a few years ago that I sold/gave to a friend and that was my brief impression.  Both are great companies and I think that it'll come down to whether you want a mic input or not, that or some other feature you decide sells you on either.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Thanks, I appreciate it, I bought the hel, love the esthetic, they will send it to me in 2-4 weeks, and yeah I want something so in the future I could buy any headphones I couldn't afford  sorry for my bad English
