How much could new thermal paste on an old card help?
Solved by RAS_3885,
Depending on that particular card's thermals and the case airflow low 80s could be reasonable. Trending high, but not danger territory. At the end of the day, the mini's heatsink is just physically smaller than most cards, so running hotter is expected.
If the thermal paste is totally dried you'll see an improvement with fresh paste and cleaning the fan/heatsink while it's apart. I'd say 5-10 C improvement realistically depending on how bad it is. Probably closer to the 5 number.
