Loud gaming pc PLS HELP
PicoMaster
I have a gaming pc that has a EVGA GTX 570 an H55 Corsair CPU Watercooler with a push pull cooling setup. It is quite loud when not doing anything and even more loud when gaming. Is it my graphics card that is so loud? If it is, is there any way to make it less loud or is there any way to trade my gpu for another GTX 570? If its not my gpu are there any QUIET! 120mm fans that aren't over $20? I have 1 200mm fan in the top of my HAF 912 case. Please help I want a quiet gaming rig!
I have a 600W Thermaltake PSU is there one that you suggest that is very quiet?
open the case and stop the fans for a second if the noise stops then it's that fan.
PC specs.3570k, asus p8z77m pro, 8gb corsair vengence 1600MHz, XFX 550w, seagate barracuda 1TB, MSI 660ti, cooler master k350, cooler master hyper tx3 evo.
Identify the source of the noise and go from there.
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
The RM PSU's by Corsair are quiet because the fan on them don't spin until they are under 50% load or something like that
Carfully stop the fans one by one and identify the ones that make annoying noises/are too loud.
If that EVGA GPU has the stock cooler i would recommend de-dusting it if necessary and setting a cutom fan curver via MSI After Burner, if you haven't already done that.
What fans are you using on your H55 push pull? What other fans do you have in your system?
who cares...
Do some stress testing and check temps while doing that. The adjust GPU/CPU cooler fan speed so that you don't mind them while gaming. Keep an eye on temps however. Set GPU fan speed low point at lowest possible. You can do it with either EVGA Precision or MSI Afterburner (same software).
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Wow this forum is a very good place to get feedback for help. Thank you for the suggestions. I have found out that my PSU is loud and one of the fans on my Push Pull array for my H55 is loud.
push pull on a h55 is going to be loud if the fans are at full speed
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
Fans, cpu cooler, gpu, psu?
