New monitor advice
Cheki
Looking into getting a new monitor, currently using a 32", 1080p, 144hz monitor, and am planning to change this into my secondary and the new one becoming primary, and was hoping for some advice, I use a 3080 atm so the gpu won't be an issue, and I'm currently considering getting a 27" 1440p, but wanted to know what others think I could should get, and some good monitors to look into (I'd like good price to performance, I don't want to be spending 400+ on a monitor), and was also wondering if mixing resolutions could affect performance
I'd recommend 32" 1440p 165Hz or faster.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Budget? That AOC 49" DQHD is a hell of a monitor when paired with FancyZones
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
This is what I just ordered:
https://iiyama.com/gl_en/products/g-master-gb3271qsu-b1/
Did some searching around on the web for reviews of monitors in my price range (sub $/€450) and this one had multiple very positive reactions from reputable reviewers. Plus it seems rather inexpensive for what it offers. Granted: When I last shopped for a monitor, a 32'', 1440p/165 Hz model would probably have cost more than my entire PC... 🙂
S.
sorry, didn't say, but I don't want over 32", since I feel like to me, over that is just a waste, especially since I sit close to the monitor
S.
Thanks
38 minutes ago, Cheki said:
Thanks
I'd recommend going with what Hardware Unboxed recommends. They do great monitor reviews.
Define "close to the monitor".  My eyeballs are 30" from a 40" display, and 40" is definitely not a waste.
Mixing resolutions doesn't affect performance...but it does create display notch issues with screen real-estate; meaning that you'll have to move your mouse to get inside the smaller display, rather than a seamless transition between equal, symmetric resolutions.
