CPU Cooler for 5950x build with CM MasterCase Pro 5
Solved by brob,
NH-D15S or NH-U12A would work. Both are available in black at a bit of a premium.
Front mounted AIO is fine. It raises interior temps a bit, but not enough to make a huge difference. If you are worried about GPU temps, move the GPU AIO to the front.
Featured Topics
ehaan ·
Posted in Graphics Cards1 -
2
INotPablo ·
Posted in CPUs, Motherboards, and Memory1 -
1
1
