I need help with an underperforming GPU.
I just bought a 3080 and With my current settings, I should be getting 200+ fps, but I'm only getting 60 fps. I've tried full system resets, clean driver installs, changing settings, etc. i have
GIGABYTE RTX 3080
ryzen 9 5900x
ASUS TUF Gaming X570 Pro Wifi
16 GB DDR4 memory
850 Watt power supply
I know for a fact it is not because of low power mode, drivers, bottlenecking, or unsupported CPU/MOBO combo. I need help as soon as I can get it so I do not need to pay for a technician, so please help?
https://linustechtips.com/topic/1416831-help-with-underperforming-3080/
Ok, what game?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
Can you run 3DMark and post results, as well as observing GPU usage and frequency ?
18 hours ago, muchy_boots said:
destiny 2
I gave a suggestion here.
Just please ask in a better way next time.
System specs below
PSU: Corsair CX650M
7 minutes ago, muchy_boots said:
can't get 3dmark, cant spend any more money at the moment. But my frequency lies at around 1850 Mhz and usage at 98-100%
You can get a limited free version of 3DMArk, but the "get demo" button is kinda hidden on Steam indeed.
Now with 1850MHz (standard for a 3080) and 100% usage it's normal, what game and what resolution do you use ? Because Cyberpunk2077 on 4K do give like 60fps with a 3080...
It's Destiny 2 at 1440p max settings, as mentioned in the other thread:
what that one guy said, 1440p on max settings should get around 220 fps and im getting 50-65
My guess is he has some weird framerate limiter setting checked
CPU-AMD Ryzen 7 7800X3D GPU- Gigabyte WindForce SFF RTX 5070ti MOBO-ASUS ROG Strix B650E-E Gaming Wifi RAM-32gb G.Skill Trident Z5 Neo DDR5 6000cl30 STORAGE- 2TB Samsung 990 Pro PCIE4 NVME x2 PSU-Corsair RM1000x Shift COOLING-Lian Li GA II Lite 360mm with 3x Lian Li P28 + 4 Lian Li TL120 (Intake) CASE-Phanteks NV5 MONITORS-Samsung G61 QD-OLED 1440p 240hz +Gigabyte G24F 1080p 180hz PERIPHERALSVaxee XE-S+Padsmith Crucible Mousepad+Monsgeek M1 V5 TMR+Autonomous ErgoChair+ AUDIO-Audient iD4 Mk II + Rode NTH100
