PSU Buzzing noise when connected to UPS
38 minutes ago, DavyJ said:So, as you mentioned, will the inductors working harder than normal cause a serious hardware problem? As far as I understand, the waves sent by the UPS are more irregular than the waves coming from the mains. For this reason, the first part of the PSU is corrected extra by the 5V stand-by circuit, which causes the inductors to work harder. In other words, the irregular energy given by the UPS is corrected "albeit the hard way" by the PSU. The resulting sound is also a side effect of this fix.
I hope I understood correctly.
In this case, do I need to switch to a different UPS or does this indicate that the UPS is faulty? Is it okay to use it this way?
Thank you.
It's not a question of working harder than normal .. it's hard to explain ....
The noise is coil whine, it's vibrations in the coil of wire that forms the inductor, because of fluctuations of power going through it.
The inductor is designed to work at a wide range of frequencies, but it's "optimized" to work within a narrow range of frequencies.
Think as an analogy like a car engine and it's cylinders - car works between let's say 300rpm and 5000 rpm but may be smoothest between 2000 and 4000 rpm
The 5v stand-by power supply in your computer works like as if it's a car climbing a mountain at a steady speed and your speed is 5 km/s (5v)
The power supply controller maintains the steady 5km/s or 5v by squirting more drops of fuel or less drops of fuel, varying the rpm of the engine, so it constantly monitors the input power, the fuel pressure (the voltage levels) .
With pure sine wave input, the controller knows the fuel pressure gradually goes up and down some amount, so it can vary the rpm a small amount and keep the speed steady.
When you have simulated sine wave, the fuel comes in steps ... for a tiny amount of time there may be no fuel at all, then it suddenly jumps to 20% fuel, then 50% fuel, then 70% fuel and 100%, then it goes back down in sudden steps 0 in sudden steps.
So when the fuel is at 0% the controller suddenly notices there's no fuel at all and notices the car speed slowing down to let's say 4.9 km/h or 4.9v and as soon as the fuel jumps to 20% the controller wants to make up for it and therefore becomes a bit aggressive and squirts more drops of fuel than normal and increases rpm much higher in order to speed up to 5v km/h or even go a bit higher than 5 km/h ... as it does this the fuel jumps to 50% , then 70% so eventually the controller relaxes again and slows the rpm speed, only to realize that again there's no fuel ... and repeat
So instead of steady rpm or let's say 500-520-550-520-500 rpm -... and so on , now the engine may work at 500 rpm, 520 rpm, 550 rpm, 800 rpm , 600 rpm, 520rpm, 500, 520... - that's what you're hearing in the inductor, those sudden bursts of engine going up to 600-800 rpm to recover from the loss of speed because there was no fuel for a brief time.
The inductor has glue and epoxy or material that's designed to absorb vibrations and whine, but those substances work best at let's say 400-600 rpm - when the inductor goes to 800 rpm, those substances are not as effective at blocking the noise and that's what you hear.
Short ... it's mostly an annoyance, it shouldn't cause a serious hardware problem. Worst case scenario, the 5v stand-by of the psu would fail, and your PC won't start and you'd have to replace the psu.
The VS series from Corsair is a budget series, where they saved pennies everywhere possible,
