Doesnt amd have better pricing right now? But who knows, my usual would be ebay... obviously not now
Seriously though, the amd line is actually pretty nutty. Its their cpus that are trash for anything that actually matters to most consumers.
Also msrp, is kinda impossible unless someone is willing to personally sell it, if you want msrp, best bet is waiting for the 7000 series amd or the 4k series nvidia and getting on a waitlist of some sort or preorder.
If I had one wish, I would ask for a big enough ass for the whole world to kiss
https://linustechtips.com/topic/1413474-help-me-pick-a-gpu/#findComment-15273235
If you want MSRP you would have to buy a founder's edition. I believe only the 3060ti has one. Good luck getting one though since for every new founder's edition card there are a million people/bots waiting to buy it, but maybe you are lucky. Easiest to get is what your local store has on their shelves, depending on where you live that might be nothing. Personally I would get the 3060ti because in theory it has the best price to performance for my use case. Think about what you want to do with it. If you only play cs:go get the 3050 for example. Then if you decide to do that, think about paying 400-500 bucks for a low tier card like the 3050, that should really cost 200. Not in this economy I guess haha. I would just wait a little longer instead of paying those prices, but that's just my personal opinion.
https://linustechtips.com/topic/1413474-help-me-pick-a-gpu/#findComment-15273293
6 hours ago, Waffletaco1 said:
I have decided to try to get a gpu new at Msrp so two questions
1. Where should I try to buy it?
2.I can afford a 3050, 3060, or a 3060 ti which one should I buy?/ which one would be easiest to get?
Good luck with that.
I really wish things were better, but you might find something, just most likely not at the base MSRP. Just a slim chance.
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz, 800x600@140Hz
Gateway VX900 CRT: 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
https://linustechtips.com/topic/1413474-help-me-pick-a-gpu/#findComment-15273786
