Budget (including currency):  ~$2000 USD
Country: USA
Games, programs or workloads that it will be used for: Gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  Brand new first PC build. Trying to find the best bang for my buck in this day in age.
Couple questions I have:
-Will the included AMD Wraith cooler be sufficient in this build? (My case has 3 fans in it, 2 pulling from the front panel, 1 exhaust on the back.)
-Will my 750W PSU be sufficient regardless if I will OC or not?
-Will I need to update my motherboard bios?
(Keep in mind I am a newbie and this is my first ever build, i will be building this soon and currently have the case, gpu, mobo, and ram)
Thank you!
https://pcpartpicker.com/list/WwDccb
https://linustechtips.com/topic/1413292-first-pc-build-feedback-appreciated/
the CPU will run hot, but it's fine enough.
More than enough.
technically possible, but highly unlikely. I'm guessing you won the newegg shuffle, so that motherboard will be pretty new, and as long as the motherboard is newer than the CPU it'll work without a BIOS update.
More than enough.
Thank you for the reply. Exactly. I was unfortunately unaware that the Mobo that came with the 3070ti was AMD only. I have never ventured into the world of AMD and didn't know what an AM4 socket was. I was told the shuffle price was worth it to get a 3070ti for $850 + the mobo which was $218. Not sure if the mobo was worth but the 3070ti was enough for me to pull the trigger. Evidently I had to change plans and switch to an AMD processor which I hope is good enough in this day in age, as well as an amd mobo which I hope wont limit my future-proofing too much.
(P.S. Will extra exhaust fans at the top of  the case be recommended?)
Probably. That case doesn't look like it has the best airflow, so either running more fans or swapping to a different case might be a good idea. The Phanteks P400a Digital is a great option for about the same price.
The case was a Christmas gift unfortunately. I will probably look up some good case fans that fit my case. Especially during summer time my room gets extremely hot.
It looks better than something like the H510, just not the absolute best. Add in a couple fans and it'll be fine. You can get a 5 pack of Arctic P12s (pretty good fans) for like $25-30
Not sure when you last got your information but for the last 5 years and up until the release of Alder Lake, AMD has pretty much given Intel a run for their money in terms of raw performance for gaming. Today when on sale, AMD CPUs are still fantastic performance and value propositions, especially considering that AM4 is a more mature (albeit EOL) socket compared to Alder Lake's initial teething issues. I'd say you're in good hands with a 5600X, since it's a year-old CPU that hasn't lost its luster yet, even if Alder Lake is a bit of a better value proposition on the mid-range options (and have a monopoly on the low-end market).
The motherboard is a bit pricey for a B550, but it's not out of the ordinary for higher-end models of that chipset.
EDIT: If you live near a Micro Center, strongly consider picking up your 5600X from there, since they're on sale for $230.
Edited by CT854
MC plug
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
I would recommend a solid air cooler to help cool the cpu better. Stock coolers lately haven't been all that great. Case comes with enough fans. However, if you feel like it's not giving you the best airflow, you can always purchase another two later (for the top of the case). You can also definitely get a cheaper monitor than that. There's one from Best Buy that's on sale this weekend. Today is most likely the last day for the sale though.
https://pcpartpicker.com/list/tN8QVw
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($267.99 @ B&H)
CPU Cooler: Vetroo V5 52 CFM CPU Cooler  ($32.99 @ Amazon)
Motherboard: Gigabyte B550 AORUS PRO AC ATX AM4 Motherboard  (Purchased For $0.00)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($0.00)
Storage: Crucial P5 1 TB M.2-2280 NVME Solid State Drive  ($99.99 @ Best Buy)
Video Card: Gigabyte GeForce RTX 3070 Ti 8 GB GAMING OC Video Card  (Purchased For $0.00)
Case: MSI MAG FORGE 100R ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: Corsair RMx (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Newegg)
Keyboard: SteelSeries Apex 3 RGB Wired Gaming Keyboard  ($39.99 @ Amazon)
Custom: WD 2TB My Passport Portable External Hard Drive, Black - WDBYVG0020BBK-WESN  ($64.98 @ Amazon)
Custom: MSI Optix G27C5 27" LED Monitor ($189.99)
$795.92
EDIT: 2TB external HDD isn't that much more. You can also get that later, and get a 5800X now instead. Just giving options.
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://pcpartpicker.com/list/hHC8Kp
Thanks for the reply. The monitor was mainly a placeholder. Better recommendations are always welcome. From comments above I feel like some extra fans would be good enough since I do have some room at the top of the case.
P.S. That monitor does look very good at a pretty good price point. The urge to swoop that up in the coming 7 hours is pretty strong right now though. You are feeding my impulse buy habit lol.
