So AIO cooler for 5800x?
Qzixas
Hey, i thinking about buying 5800x and mine 2600x stock cooler.. well i dont like it, noise and doesnt handle heat well even on 2600x heavy load.
So any recommendations?
I looking at https://www.skytech.lt/mlwd24ma18pcrw-cooler-master-water-cooling-masterliquid-lite-ml240l-rgb-white-p-565275.html?utm_source=kaina24.lt&utm_medium=referral (would mount on top)
https://www.skytech.lt/mlxd36ma20pcr1-cooler-master-masterliquid-ml360r-rgb-intel-amd-cpu-liquid-cooler-p-420540.html (side mount)
Since case doesnt support 3x fan on top.
I kinda like the first option but wonder if it works great on 5800x with is hot.
I have heard good reviews about these two but haven't tried them yet.
IceGiant ProSiphon Elite
ARCTIC Liquid Freezer II
I currently run a 5950x with a Corsair H150i Pro and it honestly doesn't do much better than the stock cooler. Runs fine and games all day until you overclock it. Auto overclocks are stable but runs at 84/85c while gaming.
Either would be fine.
The ProSiphon Elite is best suited for larger cpus like a Threadripper and is much worse relative to the competition for smaller, mainstream sockets.
