There are tubes between the fins that carry the water, as I recall.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1882866
i dont really understand your question, but i suppose you mean the holes that the fan screws go in.
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1882868
as the water passes through the tubes with fins the heat dissipates to the fins becuase thermodynamic.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1882870
the fins are pipes pretty much, they have a a large surface-area to dissipate heat, the water flows through a channel within the fin in a zig zag, not just straight through the radiator.
CPU: i5 3570K @4.5GHz    GPU: R9 290   MOBO: ASUS p8z77-v  RAM: 8Gb corsair vengence   CASE: ARC MIDI  PSU: XFX pro 550W  HDD: 2tb segate baracuda
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1882917
Like a car!
Just replace the words Engine and Pistons with CPU, GPU, MoBo, etc. Whatever you're watercooling.
LTT Recruit: Tacoma | Organization: UOLTT Conglomerate | Group: Salvage and Military | Fleet: Anvil Carrack, Aegis Retaliator and CO Mustang Omega
Appreciation to: artofinca.com | UOLTT Conglomerate on RSI and LTT
If you don't know what my avatar is, it's from: Silverhawks
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1882922
Other way around, water flows through the tubes, the fins dissipate the heat. The rad is basically split in two, forcing the water to go down one length and up the other, that's why the fitting bungs are on the same end.
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1883757
The fins are basiclly really really thin tubes that the water flows through.
EDIT:ignore that I was wrong
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1886856
No, the fins dissipate the heat, the tubes carry the coolant.
Vertical = Tubes that carry the coolant.
Horizontal = Cooling fins that dissipate the heat.
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1887034
All this time I've been wrong, thanks
https://linustechtips.com/topic/141038-radiator-questions/#findComment-1887219
