Top dust filter for exhaust?
DriftOP
hey guys i have a 240 mm aio mounted on top and i was just wondering if the dust filter of top is necessary or not as it may obviously blocking some air to flow out but removing it will let direct dust to fall in side of case and also it doesn't look good without it so i just wanted to know can keeping the dust filter harm pc in any other way as am not getting any problem currently with it in temps or any thing.
Nope but it may if it cogs
I have an ASUS G14 2021 with Manjaro KDE and I am a professional Linux NoOB and also pretty bad at General Computing.
ALSO I DON'T EDIT MY POSTS* NOWADAYS SO NO NEED TO REFRESH BEFORE REPLYING *unless I edit my post
You should just blow out the dust every now and then.
Personally, I prefer air cooling and a solid top panel, because you can simply whipe off the dust and there is no dust falling in.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
