Hi,
I'm trying to reprogram a bricked bios using a CH341A (arduino) programmer but the driver doesn't work.
I've installed it as instructed in every guide I found and the dialog box said the installation was successful, but when I try to open up the programming software it does not recognize the device.
How do I fix this?
Thanks
Ryzen 7 5700X3D (CO -30) - AX370-Gaming 5 - 2x16GB @3600C18 - EVGA RTX 3070 8G XC3
[PBO2] CO -25/-25/-30/-30/-30/-30/-30/-30
[BIOS] Vsoc 1.1 / DRAM XMP
i5-6400 4.38GHz @1.36v (162.2 BCLK) - Z170M-Plus - 2x8GB @3244C16- Biostar RX 570 8G w/ MSI Armor cooler
[BIOS] BCLK: 162.2 (x27) / Vcore 1.35 / DRAM 3244 (XMP timings) / FCLK 1GHz (1622) / RebarUEFI patched
ROG G531GT : i7-9750H (uv) - GTX 1650 +700mem - 16+8GB @2666 - 1920x1080@145Hz (up to 172Hz) IPS panel
[Throttlestop] FIVR - Vcore -160 / Vcache -105 / iGPU+unslice -125 (IccMax 255)
i5-4690K + Z97-AR + Panram Blue DDR3 2800 2x4GB Lightsaber Blue
iMac 21.5" (late 2011) : i5-2400S - Samsung 4x4GB PC3-1333 - HD 6750M 512MB - cheap Winten SSD (MacOS High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" Core 2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://linustechtips.com/topic/1408488-bios-programmers-driver-does-not-work/
Are you certain your arduino has CH341A? because not all do. I never used CH341A to flash ROMs on windows but its fairly simple on Linux with flashrom.
Huh, I just found out something about my programmer:
The PCB says CH341A, but the chip itself says CH341B. Quite a difference, tbh. I guess I should go look for a driver for the B variant.
