MSI B450i VGA light
Solved by Eastman51,
2 hours ago, Eastman51 said:Update:
I swapped the 2400G back in for a sanity check, and it worked perfectly just like before.
So I tried the 2600x, and it *does* POST; however it takes literally 2+ minutes to do so, and it won't detect the M.2 drive.
What the hell is going on with this thing?
I could try updating the BIOS, or I have another pair of ddr4 dimms I could try. The 2600x and this board really don't play nice at all.
Never encountered this level of tomfoolery with a motherboard before, but a BIOS update fixed it. Its in windows within seconds now.
The even weirder part is I was only one BIOS version behind....
