So I got my 212 evo today and it has a 4 pin fan connection. Is it okay if I plug the proper 3 fans into my CPU fan header? What will leaving that one pin out do?
Intel core i5-3570k @ 3.4 GHz - Sapphire Radeon HD7870 Ghz OC Ed 1050/1250 - Kingston HyperX 3k 120GB SSD - G.Skill 8 GB's DDR3-1600 MHz
Asus Z77-A mobo - Windows 7 64 bit - Corsair raptor HS30 headset - Corsair CX600 600w PSU - CM hyper 212 EVO CPU cooler
It can run crysis.
https://linustechtips.com/topic/140699-cpu-fan-header/
That pin is just the PWM signal. It just tells the fan what speed to run at basically. Without it, the fan will run at 100% all the time, unless you can control it in the BIOS or with some kind of software.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/140699-cpu-fan-header/#findComment-1878216
Test it and why did you get a 212 evo? .-.
Case: Carbide 300R
CPU: i5 4690K @ 3.90GHz
RAM: 8GB DDR3
Mobo: MSI Z97-G45 Gaming
GPU: R9 290 Tri-X
PSU: EVGA SUPERNOVA NEX650G
Storage: 4TB NAS
Drive 1: Seagate 1TB 7200RPM
Drive 2: WD 500gb 7200RPM
___________________________
Keyboard: Vengeance K50
Headset: Vengeance 1500 V2
Mouse: R.A.T 5
Monitor: LG 24EN33
https://linustechtips.com/topic/140699-cpu-fan-header/#findComment-1878223
I have the asus fan Xpert+ software so I can probably control it from there.
It can run crysis.
https://linustechtips.com/topic/140699-cpu-fan-header/#findComment-1878245
Go ahead and give it a shot. :)
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/140699-cpu-fan-header/#findComment-1878247
