Hi there!
I have occured issue where my CPU won't change it's clock speeds from base to boost but its just sitting at full boost even in BIOS.
I was able to set fixed clock speed via CPU clock ratio but it just stay at set value.
I would love to make it turbo only when needed and stay at base 2.6Ghz when idle/web surfing.
Intel I5-11400f
Gigabyte B560M DS3H
Thanks for all help in advance!
https://linustechtips.com/topic/1405430-cpu-stuck-at-boost-speed/
51 minutes ago, skarodwex said:
Screen is from just updated BIOS, that's why even XMP is not enabled.
I have tried many settings configuration of CPU tweaks but with no result 😞
Look for the Multi-Core Enhancement (MCE) setting in the BIOS.
Board manufacturers tend to have it set to [Auto] or [ON] by default.
And.... [Auto] = [ON]
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
