HDR doesn't work in games
Go to solution Solved by Chris Pratt,
It depends on how the game implements HDR. Many rely on the Windows toggle, so if you don't have it enabled for Windows, it won't give you the option to enable it in game. I know Horizon Zero Dawn does this.
Toggle HDR on in the Windows Display settings and then see what options you have in game.
Soo... i've had my monitor for a while now and even if it's only hdr 400 i would still like to be able to use it when i feel like it. To not mix things up, i "can" use hdr if i enable it in windows hdr mode but when i'm in games the settings tell me I don't have a HDR compatible monitor. Is there a way to fix this?
I've heard that u can use 2 DP ports to "overclock" the monitor to 144hz, is it perhaps the same with hdr that i need to have 2 DP's connected to use HDR?
My Monitor: Acer ConceptD CP3271KP
CPU: AMD Ryzen 9 5950X ||| GPU: Gigabyte GeForce RTX 3090 GAMING OC ||| Motherboard: Asus Rog Crosshair VIII Dark Hero ||RAM: G.Skill Trident Z DDR-4400 CL16 ||| PSU: Corsair HX Platinum 1200 W 80+ ||| Case: Lian Li - O11 Dynamic Evo ||| Storage: 2x Samsung 980 Pro 2 TB NVME SSD ||| Cooling: (CPU: EKWB RGB 360 AIO) (Case-Fans: Lian Li SL-120 Infinity)
https://linustechtips.com/topic/1403660-hdr-doesnt-work-in-games/
No clue what i should do since it worked long time ago when i just got it, now it only works in windows and "requires conformation" to use it in games
In your picture the use HDR button is OFF. If I'm not mistaken that has to be on, HDR mode has to be enabled on the monitor for it to work in games, if that switch is on OFF it won't work.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
It worked for cyberpunk when i did that but some other games like "Far Cry New Dawn" still doesn't work even with hdr enabled in windows
Well it worked for the games i play now a days so i don't really mind it that much, just that it's a bit weird that i can't use it on games that i could use it on before...
