Need some help
Go to solution Solved by Yume09,
IT'S WORKING!
I had to install the old MEI and run the 4th gen bios updater and it  finally worked thank you guys
So since times are though I've been been using an old rig that I'm upgrading bit my bit and rn I've run into an issue
The motherboard is an H81m-k I was using an Intel pentium g3220 before I updated bios and now I'm installing an i5 4460 and I'm getting no display, although when I switch back to the pentium signal comes back
If anyone can help me out with the issue would be much appreciated!
Full specs :
Motherboard : H81m-k
Processor: ehh i5 4460/pentium g3220
Gpu: 1050 ti 4gb
Ram: ddr3 8gb (one stick)
450w power supply
1tb hdd
https://linustechtips.com/topic/1403344-need-some-help/
Reset CMOS
even though updating BIOs should have cleared it, it would be good to try in case there's something preventing a boot.
Have you tried using the integrated graphics when booting with the i5? You might have to set the board to use the DGPU in BIOs.
https://linustechtips.com/topic/1403344-need-some-help/#findComment-15203142
1 minute ago, Yume09 said:
Bought it today, I suppose it is, I also tried an i3 4160 that I had here from another pc which I'm sure works and had the exact same issue
Hmmmm.....
This is a long shot, but have you looked at this
https://forums.tomshardware.com/threads/i5-4690-not-working-on-asus-h81m-plus.3556029/
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1403344-need-some-help/#findComment-15203148
1 minute ago, KingTdiGGiTTy said:
Reset CMOS
I will try right now
https://linustechtips.com/topic/1403344-need-some-help/#findComment-15203149
22 minutes ago, KingTdiGGiTTy said:
Reset CMOS
Tried reseting cmos didn't work still no display I switched the cpu to try and change in the bios to use the DGPU but can't find the function
https://linustechtips.com/topic/1403344-need-some-help/#findComment-15203213
